Just bought Accel 24# injectors
Old Jul 31, 2001 | 11:40 AM
Steve00YZF's Avatar
Am I absolutely going to need a chip? I have an 89 350, with minimal mods. Most of the free stuff on the site, K&N, and SLP catback. If I need a new chip, is there somewhere that I can get one premade, or do I have to find someone to make a custom one?
Old Jul 31, 2001 | 03:58 PM
LeftTurn1LE's Avatar
Well since no one else has helped you yet. I am no expert, but I think it depends. Do you have a MAF or speed density? I think you can install them if you have the less sensitive MAF sensor. I have some of these just waiting to be installed, but I have speed density, so I need some more air flow and a chip. Otherwise it will run way too rich.
91 Z28 1LE 5.7 automatic
SLP headers, random technology cats, borla muffler, Accel 8.8 wires, Hotchkis STB
boycott Sam Pierce Chevrolet
Old Jul 31, 2001 | 04:04 PM
Steve00YZF's Avatar
I have an MAF sensor with the fins ground out and the screens removed. Hopefully everything will be alright, if not, I guess I'll have to find someone to burn a chip.
Old Jul 31, 2001 | 06:45 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
That shoud be fine man, I just installed a set of those on my car about 3 weeks ago. I turned the F/P down though, but it is running lean and I plan on bumping it back up when I get a chance. I really like these injectors! I was running my original 19lbs.'ers on my 355 with pretty high F/P and they were locking up here and there. Runs great now!
Old Jul 31, 2001 | 10:02 PM
RODS92Z's Avatar
I dont think your going to need a chip for 24lb injectors. I also installed them on my 350 with no mods. Mine is speed density. Im getting 24mpg. Doesn't burn rich at all. I wouldn't worry about a chip until you find out how good the car runs.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Old Aug 1, 2001 | 03:15 AM
<font face="Verdana, Arial" size="2">Originally posted by RODS92Z:
</font>
Really? Good news for me. I'll slap those babies in this week then. Hope I get similar results.
Old Aug 1, 2001 | 09:05 AM
Kyle F's Avatar
You will need a chip to get it to run properly. The truth be known that ALL TPIS or any port fuel injection system will runn better with smaller injectors and higher fuel pressure, but if you get a chip it will be calibrated for the 24#ers and you will be able to get more fuel as you get more mods. I had a 355 with 305 heads running 13.9's consistantly on a 2.77 posi rear, so I know what I am talking about here. You need to gewt a hold of Glen91GTA. He is an ace at programming chips he can give you the gory details on how it will all work.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Aug 1, 2001 | 05:58 PM
JAY87GTA's Avatar
I've been running mine for better than a month without a problem. You can see my mods. At first I turned the fuel pressure down but that was a mistake, so I turned it back to 43 psi. Runs much better, I'm getting about 21 mpg, and most of my driving is around town and country roads in central Florida (very curvy) and I'm not nursing it for gas mileage if you know what I mean.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Aug 1, 2001 | 06:09 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I'm glad to here the good stories, I got my 24#ers in today.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
[This message has been edited by '87FAKE-IROC-Z (edited August 01, 2001).]
Old Aug 1, 2001 | 07:33 PM
RODS92Z's Avatar
Kyle he wont need a chip his isn't built like yours. A 350 with 24lb injectors will work fine with a stock chip. I know I'm running mine that way on my 355 for the last two years. I've got over 30,000 miles on it now. It runs just fine.
Old Aug 1, 2001 | 10:11 PM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
I disagree kyle.raising fuel pressure is more to fine tune athe combination.If used up too high injector pulse gets very high along with block learn,and integrator.causing the whole package to not be properly tuned.You can get away with the 24#'sbut I believe you will have to turn down the f.p.You can learn to burn your own chips for under $250.00.(go to diy site for more info.well worth it.
87 IROC WITH 409(.040 OVER400) MINIRAM,NOS(125HP)TRICK FLOW PORTED HEADS,C.C.CAM,FLOWTEK HEADERS,CUSTOM PROM,MODIFIED 700R TRANS,2400 B&M CONVERTER,3.73POSI REAREND.
LOOKING FOR THE 11 SEC. ZONE.current ets.12.39@114 mph
Old Aug 2, 2001 | 06:36 PM
cohocarl's Avatar
I just installed Accel 24s in my C-4. If you haven't installed them yet, you may want to bend up your O-rings and check to see that there isn't any excess plastic from where the two molds came together that made the injector. One of mine was leaking, so I pulled the fuel rail and that injector out. There was a tiny bit of plastic "flash" under the O-ring which made it leak. I scraped it off with my fingernail, put the O-ring back on and it's been fine.
Later,
Carl
tazs2000
Jul 15, 2017 08:44 AM
86IROC112
Sep 7, 2015 01:37 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
johanlindgren
Aug 16, 2015 12:16 AM
