2000 z 24 putting a beat on the 1986 ta tpi
Old Aug 1, 2001 | 01:42 PM
NUN's Avatar
NUN
got smoked by my friend last night he has a z24 5 speed and i believe 3;90 gears we went from 80 kilometres and i heard him rev the engine before i new it he was gone and i couldn't catch him. then after he tried the g-tech and he ran a 15.13 at 97 mph my best time with the ta was 15.5 at95mph. that is pretty quick for a 4 banger with 150 horses
Old Aug 1, 2001 | 04:17 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Sounds like somebody will be building an engine soon....
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, BBK 52mm TB, Edelbrock TES, gutted Cat, Flowmaster, CAI w/K+N cone, AFPR, TB bypass, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Alum. Driveshaft, Hotchkis STB, '99 Camaro seats.
Coming Soon!!: Fourth gen 3.42:1 rear, Spohn LCAs and Panhard.
Old Aug 1, 2001 | 05:56 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Sorry man, that's gotta suck!
That's auffully fast fot that car, sure it's not modded? Or you G-tech is really off.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
Old Aug 2, 2001 | 12:38 AM
87_T/A_LB9's Avatar
It has to be modified. I have a 92 Z34 and a Z24 will eat me out of the hole until about 40mph. Then it's lightweight doesn't help it as much as it did off of the line and a Z34 will run it back down. This is assuming both cars are stock. A Lumina Z34 runs anywhere from a low 15 to a mid 15 stock. I think a stock Z24 is a high 15-low 16 second car.
Old Aug 2, 2001 | 10:19 AM
NUN's Avatar
NUN
he changed the muffler and gutted his air box and advanced his timing he's a mechanic who no's what he did may be today will race from a dead stop
Old Aug 2, 2001 | 10:26 AM
IROC5.7TPI's Avatar
Unless we start discussing mods to beat that Z24, this topic will likely be moved to the Theoretical and Street Racing Forum.
Anyhow.... thats sad. I would do what ever it takes to get that car running right. I think you should tune it up (plugs, wires, cap, rotor, fuel filter, PCV, etc.).
I hope you find out later that the Z24 has NOS
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Aug 2, 2001 | 11:54 AM
R.O.B.'s Avatar
I own a Pontiac Sunfire, same as the Cavalier. I'll tell you, they little 2.4L engine is no joke! I even have the automatic, and it can keep up with my Trans Am with NO TROUBLE. The engine is a dirivitive(sp) of the Quad 4 engine.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 2, 2001 | 04:10 PM
prepz28's Avatar
wow that g-tech is good. i have the same year TPI in my IROC and that is the stock 1/4 time. evidently you dont have any mods. may i suggest a good cat and exhaust, worked wonders for me.
Old Aug 3, 2001 | 09:56 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
No, what's sad is I have beaten my friends old '89 IROC with my Cavalier...and it's a 2.2! He had an old 305 TBI though...still sucks!
You'd be suprised how quickly they get up to 50 mph, provided you wind the engine up, but they start to crawl at around 50-60. I was thinking of modding my 2.2 just for fun, adding a custom intake tube, ported high-compression factory head, using up my old Accel plugs and wires, stuff like that, as kind of an 'anti-rice burner' sleeper. No rice mods like Folger fart cans or big stickers.
Maybe I need to goto bed...I need to save my strength for my Camaro
Either way, it goes to show how far technology has gone with better airflow on smaller engines! VTEC still sucks, cubes rule!
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
