ZZ3 or SLP cam?
Old Jul 21, 2001 | 11:03 AM
formul8!!'s Avatar
Car: 2004 GTO
ZZ3 or SLP cam?
I can buy either cam used from a friend of mine. My set up is this:
-AS&M runners and fully matched and ported plenum
-Edelbrock manifold
-52mm T/B
-24LB injectors w/AFPR
-SLP cat back w/hi flow converters
-SLP torque converter
Which cam will work better with my setup? I will buying better heads soon (Edelbrock or Trick Flow 23*) and SLP 1 3/4 headers. Which will work better in the long run?
SLP cam.
Duration 270/280 degrees
Dur @ .050" 214/224 degrees
1.5:1 Lift .470/.490"
Centerline 115 degrees
ZZ3 cam
.05" duration 208/221
1.5:1 lift .474 .510
1.6:1 lift .510 .544
112 lobe seperation.
Thanks in advance!!
Old Jul 23, 2001 | 10:40 AM
formul8!!'s Avatar
Car: 2004 GTO
TTT
Old Jul 23, 2001 | 12:18 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
lt4 hot cam(218/228-.525in.525ex.) can be had for cheaper i would install it 1.5* advanced to build on the low end tourqe cause you don't need the cam to run to 6300 like a gen 2 motor.....however you must tap the dowel pin in a bit for it to fit under the 3rd gen timing cover.
Old Jul 23, 2001 | 02:58 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'd get the SLP cam. You have the mods now to support it for sure. After you get the heads done, it might be small.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 3, 2001 | 01:53 PM
formul8!!'s Avatar
Car: 2004 GTO
Kevin,
Should I go for the ZZ3 then? I plan on some big HP/TQ numbers down the line and don't wanna change cams every tim I do something to the motor. Will it be waaay too big for now?
Thanks!
Old Aug 3, 2001 | 02:27 PM
Jas89TTA's Avatar
I agree with Pete go with a LT4 Hot Cam. I have it in my 350 TPI and love it. But if it has to be between the ZZ3 or SLP I'd go with the SLP cam with your set up
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.5 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, Flowmaster Muffler, 3" exhaust with No Cat, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
Old Aug 4, 2001 | 12:33 AM
Kevin91Z's Avatar
I said use the SLP cam, but if you want bigger numbers then go with the LT4 HOT cam or bigger.
Old Aug 4, 2001 | 11:02 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Either of those cams won't make you a lot of top end power. For the price of the hot cam, you can't beat it. The hot cam beats both of those cams.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
buckshot63
Sep 10, 2015 09:15 AM
89fast5oh
Sep 8, 2015 09:55 AM
masonta
Sep 1, 2015 06:40 PM
