Peak H.P./Shifting
Peak H.P./Shifting
I have an 86 Iroc w/ a built 350 TPI and 700R4. It has ported SLP runners matched to a ported TPI plenum, the work was done by Dan Burk. The base and T.B. are stock except for and air foil. My question is how high in RPMs should this pull, I have heard stock TPI cuts out after 4500 RPM. Also I have a 3.42 gear and my cam makes peak power at about 4800 RPM, where should I shift for the most performance??? Thanks
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its hard to tell. Your best bet is to get the car dynoed to find out for sure.
Or, since you say the cam is built for 4800 RPMs, shift about 4800-5000 RPMs.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Kevins right, about 4800rpms to 5000rpms you should shift, I shift at 5000rpms but she pulls to that, don't say that crap about 4500rpms is all TPIs can pull too...makes me shiver
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
kdrolt
Aftermarket Product Review
Jul 11, 2001 11:32 PM
