tpi problems
Old Feb 23, 2008 | 03:26 PM
stagefright4's Avatar
Car: 1992 trans am tpi 350
Engine: tpi 350
tpi problems
here recently i broke the chip for the computer on my car and ordered one from hawks (same service #). when i put it in i had to try 4-5 times to get it to turn over. now it turns over but when i put it in drive it idles around 300 and dies. just wonderin if anyone else has had this happen to them, or any solutions would be helpful. its a 92 l98 by the way
Old Feb 23, 2008 | 05:58 PM
Bustionironi's Avatar
Car: 1985 IROC
Engine: 350HO
Axle/Gears: 10 bolt 3.23 limited slip
Re: tpi problems
Sounds like you are not getting enough fuel. When i swapped my 305 for a 350 I had to have a chip burned to increase the fuel to make it run. Before I had the new chip put in it did the exact same thing yours is doing.
Old Feb 23, 2008 | 06:24 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: tpi problems
Is this a completely stock set-up? Is it possible you had some static electricity and spiked the PROM or ECM when installing it? Also, it is possible they just sent you a bad one or the ECM died the same time this chip broke.
Old Feb 23, 2008 | 09:00 PM
Engine: tpi 350
Re: tpi problems
yeah its a mostly stock except for runners and exahust. ill get in touch with hawks to see if i can get another one monday, and hopefully that will fix it. im thinking it may be the timing is off also cause its real choppy, when it runs, but im open to all possibilities at this point
Old Feb 24, 2008 | 12:05 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: tpi problems
Don't go fishing just yet...maybe take a step back and let us know...
Why you "broke the chip"...had to be a reason why you were pulling/playing with it....
So, being the reasonng man I am, I have to ask...how was it running before you "broke the chip"?
If it was running good, why/what were you messing with to break it?
Don't take offense, but more info is better info.
Old Feb 24, 2008 | 10:34 AM
Engine: tpi 350
Re: tpi problems
no i wont take offense i was using the stuff from moates and was prying off the cover and broke the piece that has the rubber/silicone on it. it was running good before that.
Old Feb 24, 2008 | 11:18 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: tpi problems
Look through the tech articles about resetting the IAC while you're waiting for the new chip to come in.
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
