cold start plug HELP!!!
Old Aug 5, 2001 | 01:13 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Hey. We are going to dyno my AFR headed 355 next week and forgot to plug the fuil rail opening on my 1986 Iroc for cold-start. The runner is already plugged, but the back of the rail is not. Does the newer style not have an opening at all(machined different) or do they just have some kind of cap? What has everyone else used?
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Aug 5, 2001 | 01:18 PM
james_fearn's Avatar
I haven't tried this but here is a quote form an e-mail.
"Get a 16 mm oil drain plug, saw off the unthreaded part with a hacksaw, and
get a copper washer, 5/8" I think. Then use the washer and plug to plug the
end of the fuel rail. I also used Loctite blue just to make sure. About $5 in
parts at most parts stores. -JW"
James
Old Aug 5, 2001 | 01:38 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I was reading on the prom board that you could pull the cold start fuse. Would that eliminate the need of a plug or not.
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Aug 5, 2001 | 03:24 PM
Guest
Guest
Posts: n/a
Sure, if you want fuel spraying everywhere you can just leave the hole open and yank the fuse.
Old Aug 5, 2001 | 04:50 PM
Pulling the fuse is for when the cold start valve is installed as well as it's plumbing from the fuel rail. If the fuel rail isn't plugged you will have an external combustion engine
James
Old Aug 5, 2001 | 05:47 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
external...haha...lol
He's right though, if the cold-start is plugged in and the plumbing is all connected, all that is needed is to pull the fuse.
Old Aug 5, 2001 | 10:49 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yea...I will plug it since the engine is going to be run on an engine dyno this week. Very excited. Still need prom help. Only have the 305 chip. Any suggestions??? Getting stuff to make my own soon. :-)
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Aug 5, 2001 | 11:01 PM
Guest
Guest
Posts: n/a
What size injectors?
Old Aug 5, 2001 | 11:03 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
24 lbs. I know very little, but am learing about the chip part, the only problem is dyno is very soon. Any help appreciated
Old Aug 5, 2001 | 11:09 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
If anyone can also help me with the prom thing by e mail or help(In NC) my e mail is NufNuffZ28@yahoo.com
Thank You
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Aug 6, 2001 | 10:20 AM
gravitar's Avatar
Did you read Traxion's prom burning tech article yet? Lots of good info there.. As long as you don't ask people to do it FOR you, you'll find lots of people willing to help you on the PROM burning board of this BBS, too!
Old Aug 6, 2001 | 12:09 PM
Guest
Guest
Posts: n/a
Well if you are still running the 86 ecm, you need to use an 89 chip. It would be short notice for the dealer to get one but maybe you can find someplace that has one.
Old Aug 6, 2001 | 05:04 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yea. I am using a friends stock 89 350 chip right now, but I thought the chips were physically the same(27C128), just different programs. So i can program my stock chip and take the cold start out of it? Correct??
Thanks for all your help.
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Aug 7, 2001 | 12:25 AM
Omar's Avatar
And to answer one of your questions, the 89-92 fuel rails simply do not have any opening at all.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
