MAF
Old Aug 6, 2001 | 11:00 PM
Gta-Paladin's Avatar
MAF
Is it possible to port my 89 GTA l98's MAF
Or di i simply need to get a bigger one?
Old Aug 6, 2001 | 11:20 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
If you mean port it and enlarge it's diameter it's not possible. You can remove the screens and cut out the cooling fins from inside it but people have had mixed results with this mod. If you find a source for using a larger one let me know.
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Aug 6, 2001 | 11:27 PM
rezinn's Avatar
Im sure there would be a way to just make a new intake, cut the sensor in pieces and adapt it to the larger diameter(or just larger) intake.. Maybe cut the sensor and connector out and use them differently.
Old Aug 6, 2001 | 11:46 PM
R.O.B.'s Avatar
Can't do that rezinn, it would throw the calabration off. More air would inter the system then what the sensor thinks is entering, and that would cause a lean condition.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 7, 2001 | 12:34 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Go and get the Wells su-145 MAF sensor flows better than bosch one. Price 179$
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Aug 7, 2001 | 12:46 AM
how much better... 10 horse better? I've seen lt1 and ls1 mafs advertised but nothing for our engines
Old Aug 8, 2001 | 12:58 AM
irocz's Avatar
Car: '87 IROC-Z
It all depends on how much power your engine is making as to how much benefit you'll see from the maf. I wouldn't expect very much, maybe around 5 horsepower. Whatever brand you buy you're limited by the diameter of the maf and whatever sensor is inside it to measure the airflow.
I'll put it this way, when you stock one goes out get the Wells, but I wouldn't just change them for the heck of it as a mod. You'll get alot more out of porting your plenum.
Dan
Old Aug 8, 2001 | 03:30 AM
rezinn's Avatar
Yeah, I guess you're right... it needs to be in the center of a cylinder?
Anyway, listen to what Vader once said, your MAF flows more than your stock throttle body and more than your intake. So if you are going to port it, it makes no sense unless you have a modified intake to bring in more air.
Old Aug 8, 2001 | 07:18 AM
GlennS87's Avatar
Unless your seriously modded or running bigger cubes, you don't need one. They ECM can only read 255 gm's anyway. When I've run with my scantool connected, I've only touched 255 for a split second. (I have a modded MAF and custom programming). I would guess that the small HP gains that are picked up by people with near stock setups is that GM stock chips tend to run lean for safety reasons. Since the modded maf will flow more air than the computer is sensing, the tendency will be to lean out the mixture. (Just hypothesizing) I think an adjustable fuel pressure gauge is more valuable because it gives you more flexibility as you modify your motor.
Just my .02 for what it's worth.
Neptune, NJ
White '87 Vette - 383 Superram ported and matched to TPIS big mouth intake, Eagle cast crank, 6"eagle forged rods, srp/je forged pistons, LPE 219 cam, ported heads(2"x1.56" ferrea valves), Comp cams pro-magnum 1.6 rr's, double springs, titanium retainers,Hypertech power coil and cap, 4 bolt block, TPIS headers, auto(trans kit,shift kit),Pro Torque 2600 stall converter, k&N filter, 3.07 rear diff., Silver ZR-1 wheels 17x9 and 17X11
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
