programming EPROM at home
Old Feb 25, 2008 | 11:30 AM
chadp's Avatar
Car: 91 RS
Does anyone know of a cheap but effective way of programming your own EPROMS? I have a piggy back adapter and would want to program these and do not wish to burn to the factory EPROM.
Old Feb 25, 2008 | 02:22 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: programming EPROM at home
You might want to look at www.moates.net for the burn1 and tunerpro rt. If you are using the flashable AT eproms, it will work. You can also read only the original eprom.
Old Feb 25, 2008 | 02:25 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Yeah you can... go to the DIY Prom board and read up on the stickies...
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
ULTM8Z
Oct 2, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
