Injector recommendation pleeease.
Old Feb 25, 2008 | 03:35 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I think I need injectors. What size/rate injectors do I need for a 305 but that can work with the warm 355 I'm building. Is one brand better than another? What about the remanned sets on ebay?
Thanks.
Its an '89 TPI in an IROC
Old Feb 25, 2008 | 03:43 PM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
Re: Injector recommendation pleeease.
i think the 305's are 19# and the 350's used 21#. not sure if the 21#'s would hurt anything on the 305 or not tho. I usually steer clear of ebay... had too many bad experiences. Other than that i think the bosch ones are a good choice. just my
Old Feb 25, 2008 | 03:50 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
stock injectors for a 305 are 19#, 350 are 22#. I got my injectors off a seller on ebay who offers flow matched injectors and a lifetime warranty for $140. They are ford 19# injectors. The stock GM TPI injectors are junk from what I've been told(?) because they are prone to leaks/failures. I haven't installed mine yet so I can't be much help, but I (at this point) feel confident in the seller I bought mine from. (precision auto injectors) Really nice/helpful/honest seller. JMO
Old Feb 25, 2008 | 03:51 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I beileieve the 305's were 19/lb/hr and the 350's are 22lb/hr, thing is, lot's of guys have run the 19's on 350's...and run better with prom mods, now depends on how "warm" the 350 is after the rebuild if you can supply enough fuel with 19's for it...which will require you to do somer tinkering in the prom...I wouldn't get larger injectors for the smaller engine just because you're going to swap "someday".
Old Feb 25, 2008 | 04:03 PM
Engine: tpi 305
Thats not the only reason. The thing runs like crap and I want to get all the peripherals sorted out before I change longblocks. It's just about untouched at 140K mi. and I thought injectors, a regulator, and some other parts might settle the 305 down, and make the engine swap less painful. If I changed motors now, I might never sort all the bugs out.
And warm means I'd like to make 275-300 ponies without boost.
Old Feb 25, 2008 | 04:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, before you throw parts and $$ at it, might be best to correct he issues(as you mentioned)...so maybe another post with what problems you have, can get to the issues.
No use dropping 2 big bills on injectors, and have the engine run just the same
Old Feb 25, 2008 | 09:28 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Excellent advice!
Old Mar 3, 2008 | 09:55 AM
Engine: tpi 305
I've posted a couple of times and gotten some good advice on setting the tps and iac and such, but the motor still has a rough, unreliable idle and shakes at around 2500-2700 rpm, which is right where I always seem to be running. Right now I've got the IAC fully closed and disconnected. It idles rough and won't go below 1300 rpm. With the (new) IAC hooked up, it surges and dies. The EGR holds vacuum. I'm to the point of just changing stuff out, since it's all so old anyway.
Old May 15, 2011 | 06:15 PM
schmitzdonald68's Avatar
Car: 1991 Z28 Convertible
Engine: 5.7 TPI
Axle/Gears: rear discs from 88 IROC/272 gears
I also purchased some of the PAI injectors from eBay. I purchased them for my 305, but after an engine swap from a totaled 88 IROC,
Old May 15, 2011 | 06:19 PM
Engine: 5.7 TPI
I also purchased some of the PAI injectors from eBay. I purchased them for my 305, but after an engine swap from a totaled 88 IROC, I am wondering if the new "Ford" injectors would be enough to run the 350? Any ideas? It is actually pretty easy to swap the injectors so I will probably just swap them and see the difference and let you all know the results.
One more thing, how can I determine what injector connection goes to what injector. Mine are still in the "pair" configuration, but I was an IDIOT and did not mark them per cylinder when I took the old harness off.
Old May 18, 2011 | 07:07 AM
Wildflower's Avatar
Car: 1989 Iroc-Z vert
Engine: 5.0TPI 305 V8
Transmission: 700R4 Auto
I just bought Accel injectors and installed them in my 305 (stock 19# part#ACC-150819) They are awesome! They definitely upgraded them from the stock GM ones (which are made by Bosch) and the tech guys there at Accel really know their stuff. If I were you'd I'd give them a ring and ask them about your upgrade....
Old May 19, 2011 | 07:27 AM
Engine: 5.7 TPI
ok, well the engine "swap" went smoothly and is complete, now I can't get it started. It turns over, but it won't start. Any ideas?
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
