305 TPI on a 350?
Old Aug 7, 2001 | 03:38 PM
bicknese's Avatar
305 TPI on a 350?
I currently have a TPI setup for an 86 Iroc but the engine was trashed. I am now looking to put the TPI system on a 350. I've heard that the 305 and 350 TPI's are interchangable except for the PROM. I was wondering how different they were and if the one I have now (for 305) could be used and just put the TPI on a 350? Trying to do this low budget. Any advice or comments are appreciated.
Old Aug 7, 2001 | 05:16 PM
RODS92Z's Avatar
A new 350 prom cost about $75 from GM, cheapest new one you will find. Unless You find a used one. Otherwise car should run fine.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Old Aug 7, 2001 | 07:24 PM
Fastcamaro87's Avatar
ok everything should bolt up fine, as long as both engines are pre-87 or after 87 if one is pre and one after, u will have to egg the four corner bolt holes to make the manifold bolt up, u will also need some 22lb injectorsopposed to the 19lb u have now , and the prom from a 350, other than that its pretty much a direct swap, also u may be able to use the 305 injectors with a adjustable fuel pressure regulator cranked up real high...not sure tho
87 IROC-z 305 TPI 5spd 10-bolt 3.73 posi ,8.8 Accel wires , bosch platinum +4 plugs,MAF sensor screens removed, gutted air box, ram air, K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 20w50, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Aug 7, 2001 | 10:31 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Welcome aboard first off. Where exactly in MN are you I am just west of Minneapolis in Hopkins. Now to business yea it will bolt up if you have (as stated above) pre-87 305 and pre-87 350 or post 87 305 and post 87 350. You can use the 19lb injectors but you will need a AFPR. There are people here that are doing that exact same thing. It will be a lot cheaper buying or making an AFPR then buying new injectors. And yea you will have to get a 350 prom and also as stated above you can buy one from GM or if you really know cars you can start burning your own for not a whole lot more. Hope that helps out also if you are not in a car club check out www.mnfbody.com pretty cool people in that group.
Old Aug 8, 2001 | 07:59 AM
darbster's Avatar
ok guys...im a youngin so dont make fun..but could you explain to me what a prom is?
Old Aug 8, 2001 | 10:07 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
PROM
P - Programmable
R - Read
O - Only
M - memory
More accurately our cars use an "EPROM" where the "E" is Erasable. the EPROM is the "chip" that carries all the information for running your car.
Another varient is: EEPROM - Electronically Eraseable Programmable Read Only Memory
does that help?
Old Aug 9, 2001 | 12:14 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The PROM is the chip that controls the computer.
Do they really cost $75? I've gotten them cheaper, like $45-50.
To put a 305 TPI on a 350, you need a new chip (maybe) and larger injectors.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 9, 2001 | 07:52 AM
gravitar's Avatar
Another way to think of it is, since your car's ECM needs a program just like your home computer does, it has to have a way to store the program. On your home computer, you store your programs on the hard drive. On the ECM, it is stored on the PROM.
(Now I know that is way over-simplifying things, but its the idea that counts here!)
Old Aug 9, 2001 | 01:23 PM
RODS92Z's Avatar
I paid $75 for mine in Pipestone, MN at Amdahl Motors. May be cheaper for older cars.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
