TPI with only 20 psi of fuel pressure please help!!
Old Aug 9, 2001 | 06:08 PM
camaroguy99's Avatar
Well, I just replaced my 305 TBI with a 350 TPI and I finally got it to fire, well to my suprise I have 20 psi MAX. how could this be? I have replaced the fuel pump(walbro intank), fuel filter, some of the fuel lines, injectors (SVO 24#), and added a Holley AFPR. I have the regulator bottomed and thats not helping at all. Please start giving me ideas on why I am only getting 20 psi? thanks
Jim
Old Aug 9, 2001 | 08:24 PM
richie rich's Avatar
The first thing that pops to mind is the fuel filters are directional. Second is could you have a fuel line crossed somewhere. One thing you could do is put the old filter in if you still have it to see if the new filter is clogged.
Old Aug 9, 2001 | 08:35 PM
the old filter is for a TBI setup so it's a low pressure filter. I got a new high pressure one for the TPI so they aren't interchangable. I'll recheck the fuel lines but I'm pretty sure they're right. thanks.
Old Aug 9, 2001 | 09:05 PM
My car is an 88 camaro and the fuel filter is a cheap fram. It had arrows on the side for the flow direction. Did you put a tpi fuel pump in?
Old Aug 9, 2001 | 09:16 PM
Vader's Avatar
CG,
What happens to the fuel pressure if you briefly pinch the fuel return line from the regulator? If you close the line and the fuel pressure increases, the regulator is bypassing at 20 PSI (NFG). If the pressure remains the same, your problem is ahead of the regulator or you have severe leaks in some injectors.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 9, 2001 | 11:49 PM
90Form350's Avatar
Did you adjust the AFPR right? Just a thought.
1990 Pontiac Formula 350
Rebuilt 355
COMPCAMS 212/212 .440/.440 cam
Flowmasters 80 series.
Old Aug 10, 2001 | 01:52 AM
rezinn's Avatar
You can't adjust an afpr wrong, pulling the screw completely out will just yield stock pressure. Collapsed/clogged fuel line?
Old Aug 10, 2001 | 07:28 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
If Vaders check proves true (ie no change in pressure). It's going to be a PITA, but seriously consider checking the rubber line between the pump and hardline in the tank. From day one I had low fuel pressure (about 44PSI max) due to a leak. It lasted two years before blowing out totally.
Old Aug 10, 2001 | 01:17 PM
alright I'll give all the ideas a try today and post the results. thanks again.
Old Aug 10, 2001 | 02:47 PM
Well I just pinched the line and the pressure jumped to 60 psi!! So I guess that means it's the AFPR. any ideas? could I have installed it wrong or could it just be bad? Anyway I guess I'm going to rip it out again and try to figure out what I did wrong. thanks again guys.
Jim
Update:
Alright, I pulled the AFPR and the vacum side of the diaphram (sp?) was torn again . This is the second one I have torn. why is this happening? I tore the stock one and now the Holley. I'm sending it back to summit, but I don't want this to happen again. The stock one was barely hanging on by a thread. What's going on?
[This message has been edited by camaroguy99 (edited August 10, 2001).]
Old Aug 11, 2001 | 05:20 PM
ttt
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
