crusty sh*t..
Old Aug 11, 2001 | 11:48 AM
sunbound's Avatar
Car: 1987 IROC-Z
crusty sh*t..
i started making an adjustable fuel presssure regulator out of an extr. it came off an 89 iroc.... anyways, when i had it off the rail, i noticed some grey white crusty stuff where one of the fuel rails connects....
when i opened the FPR, their was ALOT of this crusty sh*t in their... just out of curiosity, what is that from? i assume it's not supposed to be in their, right?
oh, the guys that have the adjustable FPRs, did you run it from the stock loaction, and how easy is it to adjust? is it possible to change the two smaller rails around so the AFPR would mount to the front, and be easier to adjust?
thanx
sunbound
[This message has been edited by sunbound (edited August 11, 2001).]
Old Aug 11, 2001 | 09:13 PM
JETHROIROC's Avatar
Get a Holley AFPR. Pricey, but the easiest to use on the market. I can only assume you had some deposits in the fuel system from poor fuel quality or additives or just letting it sit too long without adding a fuel stabilizer. The innards of your fuel system should be slick as a minister's peter, with no deposits whatsoever.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 11, 2001 | 11:58 PM
GhoSSt's Avatar
<font face="Verdana, Arial" size="2">Originally posted by sunbound:
</font>
Usually, its from Alcohol in the gas. Ethanol up here can cause it too.
Kelly 'GhoSSt' Rosato
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
drptop70ss
Oct 4, 2015 09:44 PM
gta892000
Sep 16, 2015 12:37 AM
db057
Sep 4, 2015 07:57 AM
lightningZ
Exterior Parts for Sale
Jun 2, 2015 10:33 PM
350turbo411
Sep 23, 2001 04:44 PM
