drag tire questions.and engine spec
Old Aug 14, 2001 | 04:54 AM
iroczwrld's Avatar
i have a 89 iroc z i had the engine rebuilt:.....it has a iski cam 257 hyd intake and 265 hyd exaust...is that ok? or is it to small? the engine was bored .30 and the heads were done with a 3'angle race...and minor bowl blended...has kieth black hypr pistons .....i have the 52 mm throttle body edelbrock headers(emisions legal) cat back from edelbrock.homemade ram air , screens cut ,k&n's,i have a external accel ignition coil,sub frames, tourque arm, control arms, 2:77 gears yuck, 160 thermostat, hyperteck street performer chip, fuel pressure regulator..set at 50 psi. now besides the gears is there anything wrong with this set up? should i go more on the cam? and how much? i just bought new mickey thompsons et streets....are those good? my car doesnt hook up with what i got now(michalin xgtz4 245 50 16.... the mickeys i orderd are 255 50 16's will those help?also im getting 3:45's for gears.
Old Aug 14, 2001 | 05:02 AM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
everything sounds good to me. Just experiment with your combo and if I were you I would lower your fuel preasure a tad (42-45psi) but just play with it and see what you like best.
Old Aug 14, 2001 | 06:47 AM
Kyle F's Avatar
POrt match your upper intake with all the parts you can. You are hitting the flow limits of the stock runners and base. If I were you I would buy a set os SLP runners port match everything to them and either port your intake or get an eldelbrock piece. Everything else seems good, but a custom prom or one from Fastchip would really help to. Your fuel pressure seems to high though, are you running rich?
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
