help!!!!
Old Mar 3, 2008 | 10:20 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
help!!!!
i just got done finishing putting my headers on,i went to crank the car it fired up.so i was getting some tools up while the header stuff burn off.then the engine almost died then pick back up and then it just shut off.i look around the bat wire that goes to the starter was sparking.the wire was on the header and melted the sh*t out of it.so i pulled it off right and went back to crank it nothing.my interior light dont even come on.
i had in mind could it be the ignition switch
Old Mar 3, 2008 | 11:31 PM
88iroc52387's Avatar
Re: help!!!!
Did You strip the burnt wire down and re-solder in a replacement with some shrink wrap. If you didn't fix that wire it probably won't start. Start there and whip out the voltage meter.
Old Mar 3, 2008 | 11:39 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: help!!!!
Identify if it was the ground that fried or the 12v lead to the
starter. I can't tell you what burnt or what damage was done, the
best way is to check your crank/interior fuses, replace what was
damaged, then if you don't have power to the car look toward your
electrical components.
Ive had my fair share of electrical mishaps (especially with hedders), and
never fried an accessory. 88iroc said it right, whip out the VOM.
Old Mar 4, 2008 | 12:10 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: help!!!!
First check the battery to see if it isn't fried, then your fuses, then your fusible link. Work your way from there.
Old Mar 4, 2008 | 12:44 AM
alpine247's Avatar
Car: 1988 IROC-Z
Re: help!!!!
it was the hot wire didn't break though just melted the coating so i taped that up..and i have no voltage going to the starter..
Old Mar 4, 2008 | 08:34 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Re: help!!!!
Great, it was the hot wire, now:
Maybe say... start by getting the reading at the battery, then check for continuity from the battery to the starter and your grounds...keep going from there.
Old Mar 4, 2008 | 10:55 AM
alpine247's Avatar
Car: 1988 IROC-Z
Re: help!!!!
well i do know the battery still holds 12.83v and when i was checking that there was a big *** fuse link so i think it that well atleast i hope...
Old Mar 4, 2008 | 12:39 PM
alpine247's Avatar
Car: 1988 IROC-Z
Re: help!!!!
problem fix idk what it was i just had a long talk with her next thing i know my interior light came on and started right up
Old Mar 6, 2008 | 07:14 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: help!!!!
If battery goes dead from no charge. Follow the battery to starter path something is weak, corroded, burnt half up,or just loose. Better to fix in garage than on the road, some dark and rainy nite.
