Expert advice needed,finally buying heads
Old Aug 1, 2001 | 09:17 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I am finally going to go internal on my engine and only want to do it once the right way.I have all the necessary bolt ons allready complete.I want AFR heads but think 190's will be a little small and heard 195's don't work with a Miniram,I am going to use Comp290HR-12(230-244/510-540)or something similar,what do you think will work well with my combo??also will I need self aligning rockers wuth AFR heads??
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
Old Aug 3, 2001 | 12:41 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
1) If you haven't bought your miniram yet, then call TPIS up and tell them what you want to do with your engine. I understand you can get the miniram sized to work with AFR195 ports
2) Size your cam to your head flow and expected use of the vehicle. Cam selection is an art... ask the cam manufacturer what they'd suggest for your combo, intended use, and how rough of an idle you can stand.
3) AFR states in their literature that hardened pushrods and thier guideplates are required for use with their heads. I take this to mean they don't recommend the use of self-aligning rockers. Wanna know for sure? Call them up! The BEST place for the information you seek is the manufacturers themselves.
Old Aug 4, 2001 | 10:27 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
some of you had to have expierience with this I know theirs a lot of Minirams out there
Old Aug 4, 2001 | 10:59 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The 190's are not too small. What's 5 cc's? You can get them ported and opened up to about 205 cc if you need to. The Trick flow 23* heads are good too.
That CC306 should work fine. You only need self aligning rockers if you don't have guideplates, in other words, on stock heads. The afr's or trick flows will come with guideplates, and you will have to buy some hardened pushrods to make them work.
Make sure you get the right thermostat neck from TPIS, they act like a couple of boneheads sometimes.
Old Aug 9, 2001 | 05:02 AM
black bart's Avatar
<font face="Verdana, Arial" size="2">Originally posted by MARKT111:
</font>
About a year ago chevy high performance did a test of all the heads and AFR won i have a set of the 190 heads and they are great you will like them and they have thicker deck than others so when you step up to nitrous or superchargeing the heads will take it
Old Aug 16, 2001 | 09:27 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
will my SLP headers work with AFR heads??
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
