305tpi mods...whats next?
Old Mar 4, 2008 | 08:15 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I got a 87 305 tpi, Ive got a xr258 cam for it, ported plenum,air foil, headers,6al, rebuilt 700r4 w/2200-2400 stall, bfg drag radials on back everything else is stock. 2.73 gears wich I would like to keep for highway use. whats my next step I have @ 300 to spend whats the best bang for the buck IYO....thanks.
Old Mar 6, 2008 | 12:32 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 305tpi mods...whats next?
You looking for go fast goodies?
Ok something for looks?
Old Mar 6, 2008 | 01:14 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Look to a torque arm and lower control arms. This will help with your launch. I'd also recommend getting some subframe connectors to help with stability and longevity with the car. Just my two cents.
Old Mar 6, 2008 | 05:01 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
You cant beat nitrous for bang for the buck. Just dont get stupid with it.
Old Mar 6, 2008 | 07:01 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I know you want to keep your 2.73 gears, but going to 3.08 is not going to hurt your fuel economy that much, and is going to give you a much better acceleration. I am running at about 1900 rpm at 60 mph with my 3.42 and my 5 speed. Just my
Old Mar 6, 2008 | 07:08 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
set of 3.42 gears gets my vote.
Old Mar 6, 2008 | 07:27 PM
moomar's Avatar
Car: 92 Z28
Engine: LB9 305
400 hp hit the nail on the head. Your car won't suffer economy that much, go with the 3.42's this is where to get the bang for your buck. Just remember if thats a 10-bolt which I assume it is you need to buy a 3.42 thick gear set to keep your carrier.
Old Mar 7, 2008 | 10:04 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
exhaust...
Old Mar 7, 2008 | 10:51 AM
all4u's Avatar
Car: Firechicken
Nitrous is fun but there is something about a bad@$$ suspension and great handling that gets addictive. Remember, it will help launch and cornering.
Old Mar 7, 2008 | 12:36 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
My '91 305 TPI was a bore to drive. So I altered my air cleaner assembly and attached a K&N air cone, switched the slow 2:73 gear to a 3:42 and alumium '98 Camaro drive shaft. BIG difference car now then before. Minor cost, about 500 and change. Andrew
Old Mar 7, 2008 | 01:00 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
hello!!! the guy needs headers and a 3" catback. without those any other mods wont perform up to par. the exhaust is the most restrictive part on any thirdgen.
Old Mar 7, 2008 | 01:09 PM
Car: 1992 Formula
Axle/Gears: 3:42
I know I know, sorry! But I did the other first. I will continue when I get back to work on mine. Andrew
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
rdog30
Apr 6, 2001 07:07 PM
rdog30
Mar 9, 2001 04:25 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
