I need help with runner install.......QUICK!!!!
Old Aug 20, 2001 | 08:14 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I am trying to replace my intake runners, but I can't get the old ones off. I have the top of both seperated from the plenum, but I can't seem to get the bottom to seperate from the intake manifold or the gaskets. I have the gaskets pretty torn up, so I can't just bolt it all back together. Please advise me of how to get these free. Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Aug 20, 2001 | 08:25 PM
JETHROIROC's Avatar
There's a bolt for each set of runners that can only be accessed from the opposite side of the car. To remove the driver's side runner, there is a bolt you must take loose at the back from the passenger side. For the passenger side runners, there is a bolt you must remove near the front from the driver's side. Then just tug on them and they should break free. Hope this helps.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
