AFPR & large injectors: how do you decrease fuel pressure?
Old Aug 20, 2001 | 03:08 PM
andrew350's Avatar
OK, i know this sounds like a stupid question, but here's my problem. Even if I completely back out my bolt (on the AFPR), I believe the fuel pressure is right around stock.
The reason is because the housing for the adjustable unit is similar to the stock housing. And putting in that "quarter" only compresses the spring a little more, so how can you achieve less than stock fuel pressure?
I'm just thinking about it, and I can't picture how you'd do it.
I ask, b/c I may need some new injectors and I'd like to go with a set of SVO 24#'ers, but I would probably need low pressure to compensate. Am I wrong?
Andrew
engine related mods are few:
AFPR
slp PROM
K&N's
air foil
ported plenum
no cat (straight pipe)
cat-back exhaust
Old Aug 20, 2001 | 04:52 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You'd have to carefully bend the 'hat' so that the spring will have less tension when compressed. Basically it's impossible unless you are very good.
In other words, start burning your own chips if you want to go crazy with injectors and tuning, makes it much easier and effective.
...ed
Old Aug 21, 2001 | 01:44 AM
86_Dan_Z28's Avatar
Car: 86 Z28
You can get a Holley adjustable fuel presure regulator, with it you can increase or decrease the pressure. It is adjustable from 35-65 PSI.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
