Capped the exhuast and now problems
Old Aug 20, 2001 | 10:44 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I just capped the exhuast and now the car smokes heavily out of the PCV and the breather holes on the valve covers and out of the dipstick tube when I take the dipstick out. what could be the problem.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Aug 21, 2001 | 01:48 AM
IH8FORD's Avatar
Finally another Okie,
Anyway back to the subject. What do you mean you capped the exaust? Need to be a little more specific.
BTW you probably should have posted this on the exaust forum.
Old Aug 21, 2001 | 01:50 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
What do you mean by "capped the exhaust"?
Did you stop the flow of exhaust or what?
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
Old Aug 21, 2001 | 05:14 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Your problem sounds like a capped exhaust.
j.wolfe
_ ____ _
91 GTA L98
Best time: 14.389@95.49 (VMP)
"...Deception..." Brandon Sloan * ...wounds heal and chics dig scars...
Old Aug 21, 2001 | 11:13 AM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
if you mean you capped your header dump and make it go through the muffler now you may have a clogged muffler or something. just explain what you mean by capped exhaust.
Andrew
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
