Fuel pressure drops to zero in 1 second
Old Aug 21, 2001 | 11:10 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have a 1986 Corvette and the fuel pressure drops to zero in one second after I turn the key off. Where is the check valve located that controls the rail fuel pressure at shut down? I have read some posts that claim the check valve is located in the fuel pump and some post claim it is located in the fuel pressure regulator. Thanks for the help.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
[This message has been edited by bjankuski (edited August 21, 2001).]
Old Aug 21, 2001 | 11:40 PM
drive it's Avatar
<font face="Verdana, Arial" size="2">Originally posted by bjankuski:
</font>
It's both-already went through the same problem; it was the fuel press. regulator diaphragm on mine. The regulator lets the fuel pass to the return line and the fuel pump check valve prevents the fuel from returning via the supply line. If you pull up the rubber boot on top of the tank you can get to the return line where it is a rubber hose-clamp it; cycle the pump by turning on the key(don't need to start it). If the press. stays up with the return line clamped then its the regulator. Of course you could be leaking fuel through the injectors or a loose connector but if the injectors-that much fuel- it wouldn't start too well on immediate restart! And you should smell fuel also with inject. or pipe leaks. Hope this helps.
86 406
Old Aug 21, 2001 | 11:48 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Correct.
[This message has been edited by 3.1EyeCandy (edited August 21, 2001).]
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
