maf/sd??
Old Aug 21, 2001 | 11:24 PM
rezinn's Avatar
maf/sd??
I'v replaced all my MAF relays and the MAF itself twice, my car still won't start with the MAF plugged in. Is there any ill effect to having the car run without the sensor plugged in?(starts fine without it)
I understand that you need a new knock sensor, map, and ecm to convert, but what rewiring is required to change from mass air to speed density?
Old Aug 23, 2001 | 12:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
https://www.thirdgen.org/messgboard/...ML/004046.html
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Justin89Formy
Aug 9, 2006 07:45 AM
TRAXION
30
Jun 10, 2004 03:08 AM
