Timing for a LT4 Hot Cam
SC,
Set the base timing as far advanced as you can until the EST starts taking advance out of the equation on heavy acceleration. You'll need some sort of scanner to monitor the EST while you drive. Lacking a scanner, you can incementally increase timing a few degrees at a time and drive the car a couple of days to determine if the advance has gone too far and is actually causing EST retard. Of course, all that depends on a properly functioning EGR to help max out your EST timing.
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Later,
Vader
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Did you have Ed burn the chip for the Hot Cam? If so ask him where to set it. There is a value in the PROM that hase what the base timing is set to. If you set your base timing to something else you could possibly confuse the ECM. And, if you can't get ahold of him just try the stock 6*.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
E.T.F.A Member #11
1988iroc350tpi
Aug 14, 2015 07:52 PM
