Cam question
Old Mar 16, 2008 | 10:45 AM
87iroczzz's Avatar
Car: 1988 IROC-Z
Cam question
I have my LB9 disassabled down to everything but the rotating assembly and I want swap cams. I want to use the Crane Cams Powermax 272/284* .454/.480. Can I use this cam with my stock heads. I ported the heads with some carbide bids or atleast removed the casting marks and smoothed it up.
I want to order my parts soon, so if anyone can help that'd be great. Thanks Josh
Old Mar 16, 2008 | 02:16 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Cam question
i forgot if .460 or .480 is max lift a stock head can take but look into that before you just toss in a cam.
Old Mar 17, 2008 | 01:21 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: Cam question
that cam should work fine with the proper springs. may just need a shim kit.
Old Mar 18, 2008 | 12:43 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Cam question
I seems to me that you are looking at a non-roller cam. If you have a 1988 LB9, you need to use a roller cam.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
