Having a vaccum problem need ideas.
Old Aug 29, 2001 | 11:41 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Im posting this for a friend so you will have to bear with me. The car is a 89 305 with a 85 TPI unit converted to SD. He just put a Comp Cams Extreme Energy 218/224 .495/.502 110LSA cam in it and is having vaccum problems. When he puts it in gear the car will lobe very slowly. What are some ways to bump up the vaccum on his car. Switching the cam is out of the question since budget is the key to the whole situtation. He is getting a custom prom burned for him which he will be putting in hopefully today depending on how fast TPIS works (man I love having them so close) and he is putting a vaccum canister in it as well. What are some ideas you may have to help him combat this problem. Thanks in advance.
"I'm not dumb, I just have an amazing command of thoroughly useless
information."
Bill Waterson creator of Calvin & Hobbes.
Old Aug 29, 2001 | 06:19 PM
cobrakiller1989's Avatar
Im not 100% sure bu ti think TPI needs LSA to be around 112 or higher to get enough vacuum.
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Aug 29, 2001 | 08:25 PM
JETHROIROC's Avatar
The chip should make a substantial difference, but that cam is too much for a street-driven otherwise stock 305 TPI. Too much duration, too little LSA, too typical of a mistake. Unless he's made other mods to complement the cam I would advise him to jerk it on out and be more realistic with his next cam selection.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 29, 2001 | 10:55 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Thanks for the info. Cobra you are right the TPI does need 112 LSA that much I know and Jeth I told him in the begining to just get a 350 cam for the thing it would be a great cam since it comes in the 5spd 305 but he didnt and now he is stuck. I am thinking that we will need to bump up the idle on his car to try and help with the problem. Any other ideas?
Old Aug 30, 2001 | 12:10 AM
VetteMan's Avatar
Agree...change out the cam....life will not be good toll you do!
V/R,
Frank
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
rjcme
Sep 5, 2015 01:23 PM
andy74
Sep 3, 2015 08:41 AM
