TPI in a older 350?
Old Mar 19, 2008 | 11:31 AM
sheppyfire87's Avatar
TPI in a older 350?
i have a 350 for 69-79 i think and i was wondering if a TPI setup from a 85 iroc would fit on it. thanks,tim
Old Mar 19, 2008 | 12:05 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: TPI in a older 350?
yes it will as long as you have all the correct sensors
Old Mar 20, 2008 | 02:45 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'85-'86 TPI intakes have the older-style intake bolt pattern, so you're fine. It was in '87 and newer that have the different intake manifold bolt angle.
Old Mar 20, 2008 | 10:54 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Keep in mind that you will need to use 24lb injectors for that 350. 85-86 systems were only used on 305's in camaros/firebirds and use 19lb injectors.
Cheers!!!
Old Mar 20, 2008 | 11:09 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
So that means what for '87-up? You can only use '87 up to '97 heads?
Old Mar 20, 2008 | 11:42 PM
Car: 83 z28
87-up had a different bolt angle for the intake manifold, in 1979 the heads accepted the standard bolt angle intake manifold making the early tpi a better choice. Also in 87, cams were now roller, and the old 2 piece main seal became 1 peice.
cheers!!
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
