im going port crazy
Old Sep 6, 2001 | 08:44 PM
85witetrannyam's Avatar
im going port crazy
besides heads can u port the stoick plenum intake runners ??is there enuff meat on them??
Old Sep 6, 2001 | 09:34 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Yes, you can port anything you want! Including your exhaust tips!
No not really on the tips, but yeah the plenum is very portable. Remove the walls directly behing the throttle bores (lumps coming up from the bottom of the plenum with little holes behind them). then gasket match the runners to the plenum and then the runners to the base, and the throttle body to the plenum.
If you want to get really dirty you can pull the manifold and gasket match it to the heads. And take some out on the manifold ports and remove any casting flash.
Beyond this there isn't much to do with the stock runners since they're made of tubing and not cast.
You can port anything if there is enough material.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
<img>http://www.geocities.com/gillowtex/outside12-small_engine_copy.jpg</img>
Old Sep 6, 2001 | 09:54 PM
ok the gm name is at stake here i made a bet with my buddy who has a 88 gt that my ta will be faster than his stang.so what can i do to get the most out of my 305 or should i just buy a crate motor?can some body give me like a list of parts or possibly somebody out there has some used parts or maybe a motor?help please oh yeah i am puttin 373s in it also which should help me out.
Old Sep 6, 2001 | 10:16 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
well I am guessing that you hvae an 85 T/A with TPI. Good news your car is pre-peanut cam. So you have stock for stock 215hp. Do a complete exhaust on the car along with porting everything like you said. I would suggest dumping the stock runners and getting some aftermarket ones that could be ported and siamesed. Also gears like you said but don't go above 3.42 with TPI. ALso get a stall converter for it. A cam would be a good idea later down the road or a swap to a 350.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
completely done over suspension, black paint with flames,
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
Old Sep 6, 2001 | 10:30 PM
ok ive got a ? here.if i wanted to build a 327 stroker what do i have to do do i have to bore the cylinder out and buy the stroker kit or just buy the kit..im very confused about the whole stroker concept.how much horsepower are we talkin if i build a stroker and slap in a cam and port the heads??also can i use the tpi set up or do ii have to convert to carb?thanks guys
Pac J
May 17, 2020 10:44 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
