How Much Horse? Any Sugestions?
- 350 ZZ4 Block
- AFR 195 Heads (64 cc)
- Fully Ported and extrude honed Superram intake and manifold
- 58 MM TB (may get S/C later
- SLP 1 3/4" w/ 3" ypipe
- 3" pipe for Cat
- Hooker 3" catback
What kinda horse will thise make??? Do you see anything that should be changed or anything if money is not a problem? Suggestions?
- 3" pipe for Cat
- Hooker 3" catback
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you will lose about 1/2 point in compression from the stock l98 aluminum heads shouldn't see a big loss due to that combo sounds good depending on the cam should run really strong for you.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
car has found a new home
she will be relocating soon,thanx to all that were interested and the few who had purchased some of the many,many extra parts i had accumulated over the years.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
Chevy3shitty
Sep 1, 2015 02:10 AM
