PROM ID
Old Sep 1, 2001 | 03:32 PM
JETHROIROC's Avatar
PROM ID
Hey guys. I pulled the ECM on my 1990 350 IROC with an auto, and the numbers on the PROM are as follows:
Delco ANJF
4307
014
045915
AB8927B
The ECM has service number 01227730, and also the number 16125181.
Can anyone identify these parts for me? Also, is there a more updated Memcal that may provide better performance. Thanks.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 1, 2001 | 11:37 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Sorry Jethro, this forum is for those who need help programming their own PROMs. DIY PROM burning = Do it yourself prom programming. Transferring to the TPI board.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Sep 2, 2001 | 09:10 AM
JETHROIROC's Avatar
Thanks Tim. Sorry 'bout that!
Old Sep 5, 2001 | 03:38 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
JETHROIROC,
The only thing I can really tell you is that 1227730 is the GM part number for a Speed Density ECM. You probably already knew that, but at least this will put your questions btt.
If you don't want to burn your own chip, the best aftermarket chip I've heard is FASTCHIP.
Hope it helps a little.
1992 Pontiac Firebird Formula (original 305 TBI) The project has begun:
just purchased 1986 Corvette 350 TPI, Summit SLP 1 3/4" Headers, Dual Catco Cats, Flowmaster American Thunder 3" Exhaust, Dual fan setup, OEM Posi, GM 3.42 gears and JEGS Ultimate Support Cover for 7.5 rear.
1997 Chevrolet Camaro SS # 379 (1 of 371 Black, T-Top, 6-speed)
1973 Chevrolet Camaro RS/Z28
1969 Chevrolet Camaro SS 350
RIP Dale Earnhardt.
Old Sep 5, 2001 | 07:45 PM
mckenzie's Avatar
Hey Jethro, i work at a gm dealership (don't tell anybody :eek i will try to see if there are any updated proms for your veh. i have a 86 iroc and it had an updated prom to solve many problems. i will try to get back to you in the next few days... i have jury duty tomorrow. so it may be friday. where do you live in tennessee? later, tom
86 iroc 305tpi auto. mild cam
Old Sep 5, 2001 | 08:09 PM
JETHROIROC's Avatar
Thanks guys. Hey mckenzie, I appreciate it. I live in Maryville, isn't that about an hour from you?
Old Sep 7, 2001 | 06:03 PM
mckenzie's Avatar
hey jethro, i need your vin to check for updated prom's on your car. i thought i could just type in your prom and look for updates, but no luck. i need to know your vin, tire size, and emissions.(likely federal, unless bought in cal.) then i'll try again on monday. thanks, tom
Old Sep 9, 2001 | 11:09 AM
mckenzie's Avatar
hey jethro, i need vin for prom search. thanks, tom
Old Sep 9, 2001 | 11:55 AM
JETHROIROC's Avatar
Thanks for the offer, tom, but now I feel like an idiot. The new part # is right in Traxion's prom burning article:
"Also, for your information, the current GM (AC Delco) part number for a new MemCal unit for all 1990-1992 350 F-Bodies is 16151348."
I can get it on AC Direct for under $40, so I think I'll go ahead and order it. Again, thanks for your help.
Old Sep 11, 2001 | 03:42 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Hey mckenzie, where did you get that updated PROM chip? What part number is it? I have an 86 IROC with problems that could be related to it. I have sent you an e-mail. If I go to my dealer and ask for the 86 PROM will it be the updated one or the old one?? I was about to purchase but waited to get more info.
Old Sep 11, 2001 | 06:41 PM
mckenzie's Avatar
if you go to a gm dealership, they will need to know all the info on the car. tire size, motor, type of trans, etc. they won't know exactly what the new prom update's (parts dept. that is.) if you send me your vin, i can tell you what the new prom update will help on your veh...ie..false ses light, etc. best of luck, tom
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
