Please help..Smoking and codes...
Old Mar 30, 2008 | 05:38 PM
pa_richardson's Avatar
Please help this engine is getting better of me..
TPI 5.7....Speed density....
The engine fires up ok stumble on idle but smokes very bad which smells like fuel.
Its showing Codes 15, 43....
I have changed IAC, Electronic Module, Dis Cap, Rotor arm, Leads, plugs, Temp Sensor, ECM, MAP sensor, battery, fresh fuel, fuel regulator.
I have had the injectors out they not leaking, cleaned everything whilst it was all apart...
The emmisions bits have been removed the EGR is blocked off...The SMOG pump is still in place but disconnected.
Any help appreciated..thank you
Old Mar 30, 2008 | 06:09 PM
bonesbrakr's Avatar
Re: Please help..Smoking and codes...
i read your other post also..... most times you cant visually inspect the diaphragm on the fuel pressure regulator.... best way to see if it is the regulator is with the motor running pull the vacuum hose off the regulator.... if gas is shooting out then its bad.... if not then its good.....
Old Mar 30, 2008 | 06:16 PM
Hi i have had the regulator of the diaphram is fine i have also added an adjustable one for future tweeks..
Thanks any how
Old Mar 30, 2008 | 10:55 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
code 15 is cts, replace it and see wat happens i had theres on on ebay for 9 dollars
Old Mar 31, 2008 | 03:27 AM
Hi yes i have changed that maybe the new one is faulty?
I will try another...
CORV3TT3
Aug 23, 2015 11:26 AM
Slick71ss
Brakes
Nov 2, 2012 04:48 PM
davila0115
Sep 23, 2011 04:02 PM
98t595
Jun 1, 2011 08:29 PM
DaRKSLaiN
Aug 25, 2009 05:38 AM
