Getting code 24 (VSS) after 5 spd swap......
Old Sep 16, 2001 | 10:04 PM
86IROC305's Avatar
I just got done swapping my auto to a 5 spd in my 86 and took it for a test drive. About 15 min into the ride my SES light came on and my speedo quit working, so I went home and pulled the codes. I am getting a code 24 for vss, when I didn't think 86 had a vss. Is there anything else that could cause this ?
86 TPI 305 Iroc-Z
700R4 (rebuilt)
9 Bolt Rear Disc Swap w/ 3.45's
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Sep 16, 2001 | 10:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have a cable speedo, but the computer still gets a speed signal electronically. Since your speedometer quit, I'd look and see if your cable is connected to the trans properly, if its connected to the speedometer properly, and make sure its turning, not bound up inside.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 16, 2001 | 10:59 PM
86IROC305's Avatar
I thought the cable might have gotten screwed up some how, but I'll have to wait till tommorow to check. Were does the computer pickup the signal from ?
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
