idle adjustment
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: idle adjustment
there is a little screw on the throttle bracket. when the cable and spring come back to rest they hit it. right there on the throttle body. i know that is one adjustment.
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: idle adjustment
Take in mind that adjusting the idle screw, will change the tps sensor voltage... Should be somewhere around .54 - .61 VDC This will also change the IAC Valve, after adjusting drive the car above 40mph to reset the Idle Air Control Vallve. Hope this helps,,, Good luck!
