Cold Start Injector Fuel Pressure
Old Sep 18, 2001 | 08:08 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I've got a 1987 fuel rail with cold start injector provisions. I'm going to be running a 1990+ speed density system that automatically enriches the cold start mixture. Would it be possible to run a fuel pressure gauge from the fitting from the deleted cold start injector? If so, does anyone know the thread count/pitch?
Old Sep 18, 2001 | 01:46 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I too have the cold start setup and am switching to the 90-92 Speed Density system.
Can I just leave the CSI attached to the manifold and just have the injector connector disconnected?
Thanks,
Old Sep 18, 2001 | 10:08 PM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Zepher,
Disconnecting the CS injector connector, or the Thermal Time Switch connector (big brass thing on the front of the intake manifold) will work, but it is even cleaner to pull the cold start fuse.
Kevin
Old Sep 28, 2016 | 09:27 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: Cold Start Injector Fuel Pressure
Hawk's makes a delete kit that eliminates and blocks off the entire thing...$30.00.
http://www.hawksmotorsports.com/85-8...or-delete-kit/
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
