basic performance
Old Apr 5, 2008 | 03:13 PM
LCC.GTA's Avatar
basic performance
I want to work on my car, and make it perform better. I don't have an engine hoist or the stuff to pull a motor. I have a budget of about 500 bucks and I want to do the work myself. What performance parts can a 17 yr old back yard mechanic put on to make my car stronger with this type of budget?
Its a 350 TPI that I'll be workin with.
Old Apr 5, 2008 | 03:25 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: basic performance
k&n air filter, shorty headers,port the plenum,port the intake and runners,go to the tech articles look for free mods,do a good tune-up ,change fuel filter,oh (edit) adjustable fuel pressure regulator later jimmy
Old Apr 5, 2008 | 04:12 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Definitely a set of headers and new y-pipe. And if you have the ability to port everything, definitely do that as well. Well basically, do everything jimmy said.
Old Apr 5, 2008 | 04:33 PM
Abubaca's Avatar
Pretty much every single part on my car is new or rebuilt, and after doing all that, if you were to give me a bone stock 5.7 TPI, assuming all the maintenance had been done and everything ran well, here's what I'd do.
First would be headers/catback (you'll have to shop but you can probably find something for around $500 used.)
....then would be a rear end gear and a torque converter. I bought a used 3.27 rear end for $200, and a used B&M 2400 TC for $200. Although after reading, I wouldn't go B&M again, mine has served me well. Easily the best single mod I've done.
.....but keep in mind that for $500, you can only go so far. Pretty much the only thing my car has that is weak is the stock heads. EVERYTHING else has been done. Sure, that's a big part, but I've still got THOUSANDS in the car, and I'm still getting beat by stock LS1 cars. Nothing that anyone has mentioned is really gonna do major things for you. You'll feel the headers help you out, and the gears and TC will help too, but you need to decide what your goals are, and check your pocket book. To be completely honest, if the car has been tuned up and maintained properly, I'd probably just keep the $500 bucks until you're "really" ready to start modding. I didn't start modding mine until I had a daily driver and a decent job!!!!
Old Apr 9, 2008 | 12:53 AM
darkcrave's Avatar
Cat-Back
Old Apr 12, 2008 | 10:14 AM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
im 17 aswell...but for now i would say maybe a CAI new catless y pipe and a catback lol
Old Apr 13, 2008 | 02:12 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
keep the cats, ditch the mufflers, run 3'' from the cats, sounds good, performs better that way... thats a budget exhaust that realllllly pays off...
next would be the cold air intake system.... after you have the intake and exhaust on, get a fuel pressure regulator and dink around with that until you get it just right.... 500 bux u should pull those 3 mods off with money to spare, and you will really like the difference...
Old Apr 14, 2008 | 08:43 PM
Abubaca's Avatar
Ummm, yeah....I dunno if ya really wanna do that. Without a big lumpy cam, it's gonna sound crappy. Plus the cats are more of a restriction than the muffler. And either way, with the 2.5" cat inlet, the 3 inch out would be worthless. Unless you dump the cats (which is illegal) theres' no point ditching the mufflers.
Old Apr 14, 2008 | 09:22 PM
irocz28boy's Avatar
Car: 2000 Z28
Agreed. Ditching the muffler isn't the best idea. I would suggest headers into a full 3" exhaust system. Instead of a CAI, just look up on this website how to make the ram air through the fog lights. Much cheaper and just as effective.
Just to let you know, I'm 17 as well and I did the majority of my exhaust, minus the welding it required due to a crappy y-pipe. Plenty of things are possible for a "17 year old back yard mechanic".
Old Apr 14, 2008 | 09:38 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Yea im have a budget of $500 dollars too go with. Here are my plans
Cut off cat convertor
headers
Y pipe
Cold Air intake
Old Apr 15, 2008 | 05:09 PM
Abubaca's Avatar
headers
Y pipe
Cold Air intake
The OP has a Firebird, so I don't think there's a "fog light" CAI mod on the boards. Not sure since I'm a Camaro guy myself. On the Firebirds, they DO have a restrictive air intake from the factory, so SOME sort of intake mod is helpful.
On TPI Camaros, the dual intake flow plenty of air, even for pretty heavily modded motors, and of course, it's ALREADY cold air. No need to modify it, ESPECIALLY if you're on a budget.
Old Apr 15, 2008 | 07:00 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
Is the car in good mechanical condition? Find a cheap nitrous kit and spray it. Best bang for the buck. Aside from tuning the car up, my setup is a $100 wet kit (75 shot), $30 purge, $35 nozzle, $50 bottle fill, $150 headers, $100 Y pipe, and $35 in MSD wires. The muffler and filters were in the car when I bought it. It made 260 hp and 404 ft lbs with a 305. I only spent a total of $500 on this setup, but keep in mind, a $50 bottle fill doesn't last too long!!
Old Apr 15, 2008 | 09:12 PM
irocz28boy's Avatar
Car: 2000 Z28
Yeah I didn't realize the OP had a Firebird. Some sort of air intake would be a good idea then.
Old May 8, 2008 | 11:58 PM
Nater36's Avatar
guess thats why you muffler guys have that distinct missed timing sound, mine sounds great and its not too loud either.
Old May 9, 2008 | 10:49 AM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Full exhaust, Intake and runners, 3.45 gears, and a 2800 stall would yeild the best performance gains for the money.
Old May 9, 2008 | 12:11 PM
mean57's Avatar
Car: 87 gta
don't know where he lives but il law passed says no more emmisions testing for cars with the obd1 system. only 96 and newer being tested here now
Old May 9, 2008 | 12:34 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by LCC.GTA
I want to work on my car, and make it perform better. I don't have an engine hoist or the stuff to pull a motor. I have a budget of about 500 bucks and I want to do the work myself. What performance parts can a 17 yr old back yard mechanic put on to make my car stronger with this type of budget?Its a 350 TPI that I'll be workin with.
You'll want that 350 to breath, so toss the stock TPI setup, and look into an alternative (you'll need to save a tad more though, but it'll be worth the wait). If it were my car, I'd go with a Holley Stealth Ram, w/the proper stall speed converter. These two items alone (with the right tune to boot), would make one heck of a difference....
UltRoadWarrior9
Apr 28, 2020 10:39 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Veaceonee
Sep 29, 2016 08:15 PM
tyeo098
Nov 30, 2015 06:27 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
