Anyone have any experiance with SLP's TPI proms?
I was wanting to change out my prom for two reasons, I just swapped from a auto to a 5spd and wanted to get rid of my c/s injector. I figured if I get one of the SLP proms for $69 on clearance (same price as a dealer stock chip here) for a 89, it will will cure both my problems and they state they have made performance upgrades at WOT vs the stock chip.
Has anyone used a SLP chip with good results ?
86 TPI 305 Iroc-Z
5spd
9 Bolt Rear Disc Swap w/ 3.45's
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
Car: `86 SS / `87 SS
TTT...
Would an 87-88 PROM work in my 86 Iroc TPI setup? It's all stock parts, just swapped into an 86 Monte SS.
I want to upgrade b/c I went w/ a five speed & I have an auto PROM right now.
Matthew
jmd
1986 SS with...
86LB9 TPI atop the original L69, hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
Matthew
jmd
1986 SS with...
I have never used an SLP chip, but to the other question I believe an87-88 chip would improve things but Im not sure, you could do a search on this board to see, Im sure someone else has discussed that and it improved it.
hope that helps
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
hope that helps
The SLP/Jet/Hypertech chips work, but if I had my choice I'd stick with the good Ol GM memcal/chip. If you do any prom tuning at all you'll notice that the difference between the proms is slim to none. But in the situation your in right now its a toss up since the prices are about the same...
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Brendan
Thanks, I think I might try it. I've heard of people swaping the 86-88 proms with a 89 to delete the c/s injector, but I want some clarification before I try it. Here's a link to the page : slponline.com
BTW. What is the main difference bettween the auto/manual chips besides t/c lockup and shift idle control(5spd) ?
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
86, I ran an SLP PROM for years. Honestly, there was little if any performance improvement over stock in my case (stock except for headers, catback, and the cheap mods). The main reason I continued to use it was because it turned the fans on at a lower temperature.
My suggestion would be this. If you're never going to get into PROM burning, either one will work fine. If you do plan to try your hand at making your own, I'd go with the good old GM memcal since I think it's a better base upon which to create your own.
Ooops, I forgot to mention that the 89 chip is going to have VATS enabled... Unless you "disable" vats it won't let the injectors pulse.. So your going to need programming equipment either way..
Brendan
Brendan
If I can find a dealer around here any cheaper, I'll probably go with that (I haven't called around that much). I do plan on getting into prom burning, just haven't talked myself into investing in the equipment/software yet.
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
To answer your question, no you just cant plug an 89 chip into your 86 computer without modifying the programming somewhat.
You really need a custom chip, and buying the equipment to do it is a lot less than what some places are charging for their "custom" chips.
The chips are NOT different. 86-89 are identical. 90-92 gets into SD which are different.
I run an 89 calpak with custom ARAP programming in my 86 computer.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
So, the 89 chip would work if I disabled VATS. I guess now is a good time as any to get into prom programming. I've heard some good things about the ARAP bin and like to try it out. Would I see a power increase with a custom chip or just drivabililty issues? I've never seen anyone with dyno results before/after they installed a custom chip and I guess the results vary depending on how badly you need one.
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
86 TPI 305 Iroc-Z
5spd
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
