Factory roller cam?
Old Apr 6, 2008 | 01:12 PM
tyjax's Avatar
Factory roller cam?
Hey fellas. New poster here. I've got a question. Does my 85 Iroc-z 305 TPI have a factory roller cam? Also, are the disc brakes on the rear axle rare? Thanks
Old Apr 6, 2008 | 08:29 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Factory roller cam?
TPI's started coming with factory roller cams in 1987. Assuming yours is all stock, it wont have a roller cam.
Old Apr 6, 2008 | 08:48 PM
tyjax's Avatar
Thanks.
Old Apr 16, 2008 | 07:15 AM
czbigboy's Avatar
Car: 85 IROC Z
My 85 Iroc has drum brakes on the rear. I dont know if disc on the rear are rare, but I would def want them.
Old Apr 18, 2008 | 01:43 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
You can have rear discs on an 85, but the setup-from what I understand-is sorta a crap system. I have heard of the calipers seizing up easily. Also, they are smaller than the later BW 9-bolt setups, which had aluminum calipers and larger rotors. I would switch to that if possible.
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 8, 2015 09:37 PM
