gm cam # 10066049
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
gm cam # 10066049
Anyone know where I can find one of these cams. It should be the number for a 89 LB9 with standard trans. It's eather rated at 225 or 230 HP. perfect for a CMC engine.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: gm cam # 10066049
This is an old, ancient thread but why would you want one of those??? Sealed Power CS-808 is the same grind.
Also I would go bigger if I were swapping cams.
GM makes a very nice cam that is right between the ZZ4 and LT4 Hotcam.
GM Part Number 12677151
Comes in the GM SPO 350 making 357 HP.
Its a roller cam specing 215/223 @ .050, .474/.474 lift
Car: 1991 RS
Engine: 5.0
Might need it for a stock motor class? The CMC series the OP mentioned requires stock motors for competition. The rules have changed since 08 though to allow one aftermarket cam.
