Problem when going full throttle
Old Apr 7, 2008 | 10:44 AM
Funk's Avatar
Hey I'm not entirely sure what is wrong here but since I've owned my '87 Z28 with TPI, whenever I gave it full pedal to the floor gas my car just pretty much craps on itself and doesn't give any power just revs up passed redline and I repeat, delivers absolutely nothing to the wheels it feels. However if I play with the throttle and let off a bit it will switch and put me back in my seat, but I am definitely lacking a bunch of horsepower due to this. I had a friend who is a former mechanic and camaro owner check this out and he said he is unsure but we will start by changing my timing. Any ideas here?
Old Apr 7, 2008 | 02:57 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: Problem when going full throttle
check your tps sensor to make sure its properly calibrated. checking your timing is a very good idea.. the previous owner may have altered it for some reason, and you are just the recipient of their bad decisions.
Old Apr 7, 2008 | 09:05 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Sounds like it might be a fuel problem. Get a fuel gauge and check the fuel pressure....should be about 38-42psi for TPI and around 13 PSi for TBI. Also change the fuel filter if its been longer than 30k miles since last replacement.
Old Apr 7, 2008 | 10:47 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
adjust the tv cable ,go to technicle articles on homepage. explains how to adjust, later jimmy
Old Apr 8, 2008 | 09:13 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
One thing that happens, when you lift the gas at wot, is the tranny (700R4) shifts into OD. Vettes and police will shift at wot (unless the tranny has been swapped when rebuilt).
A Corvette TV sleeve and plunger will give WOT 3-4 shifts.
The 3-4 WOT Shift valve from GM is #8673948.
It's made by GM for the Caprice police cars but will do the job.
Old May 4, 2008 | 07:56 AM
bgood71's Avatar
Car: 89 GTA
If the motor just revs when you stomp the gas you need a trans. The TV cable adjustment will not likely cause only a full throttle shift problem, but would also have lazy or harsh shifts also. I just recheck the post to see if it was fixed yet and couldn't believe I missed the revs with not power statement.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
92camaroJoe
Aug 13, 2015 06:07 AM
