Idle and Injectors
Old May 3, 2008 | 03:30 PM
epsmotorsports's Avatar
Idle and Injectors
Two questions for you Gurus out there. (i always use the search feature for my questions before posting and sometimes i can't find the answer i need. Also some threads just need to be updated)
Question 1: I have a 383 TPI motor with new cam. How do i Know where the car needs to Idle? I understand how stock motors idle but this is not stock. I do use Tuner Pro RT so are there numbers i need to be looking at?
Question 2: I have 30lb rochester high impedence injectors and am running richer than bill gates. I know only because of the smell and the black plugs i pulled. Using Tuner Pro is there numbers or something i need to look at? Are the injectors too big? the pressure is set at 47psi. I am wanting to get 400 plus horses.
Old May 3, 2008 | 09:25 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Idle and Injectors
Question nr 2: you need to adjust the injectorsize in your prom...
Did you have it tuned for your setup ? its a must when you've changed the engine that much...
You idle maybe will be good around ~800rpm ? try some different rpms out and see where it idles the smoothest..
Old May 4, 2008 | 06:38 AM
Prom was set at 24lb injectors. the guy who made the prom said 24lb would be sufficient i just wanted third gens 2 cents.
Old May 4, 2008 | 09:18 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Well 24# is not going to work for 30# injectors. I'd defintely get that fixed first.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
