"HELP " Will 87 TPI work on my 350???
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I was wondering i am looking into buying a tpi unit and i found one. But it's off an 87' IROC which is a 350.. It has no injectors in it but that's no problem. But I was wondering, I read somewhere, where the bolt holes for the intake are drilled at a different angle in the older TPI units. Where as on the motors like mine are drilled straight down ...or visa versa(not sure exactly how it went)......I guess the easiest way for someone to answer my question is .......WILL THIS UNIT BOLT DIRECTLEY ON MY MOTOR AND BE GOOD TO GO? It has everything,sensors,distributor.harness.ecm MODULE...etc.etc...NEED HELP ASAP
92' Camaro RS/Black,T-tops/350 TBI Targetmaster Comp.engine/5 spd/march underdrive pulleys/hedman hedders/3" dynomax exaust/hyper tech stage 2 chip/3.42 gears/K&N air filter/MSD blaster GM coil
1992rs/ss
Jan 31, 2025 05:10 PM
