Tpi fuel stuff
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
Tpi fuel stuff
Slowly but surely I am gathering parts for a tpi swap. I have almost everything, but my injectors are for a 305. I read that they are 19.3lbs @ 43.5 psi. Is this true? Is there any way I can use these in my 356 application?
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: Tpi fuel stuff
if you get an afpr and boost the pressure, you might be able to fake it for a bit, but your best bet is to get some 22 or 24lb injectors.
on a side note, i just bought some type III bosche (rebuilt with 3 year warranty) from fuel injector connection. damn good prices, and u can't beat the warranty
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Tpi fuel stuff
Car: 89 iroc
Engine: l98
Re: Tpi fuel stuff
put in the 3rd gen bosch.. big job because i detailed the engine. just got back from an hour drive.. car runs great.. easy starting no more hesitation
thanks jon!!
thanks jon!!
Car: 89 iroc
Engine: l98
Re: Tpi fuel stuff
i bought the flow balance set. 169 for all 8 3 yr guar.
heres the link of their store
www.fuelinjectorconnection.com
if you call ask for jon
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Tpi fuel stuff
the 19lbs injectors will WORK at an high pulse width and they will get bad faster.. It will work but you will shorten the life of the injectors, and also If you got an stock tpi intank fuelpump dont go over 50psi (because that will hurt the pump over a long time..)
If you have the $$$ in some near future, buy atleast 22lbs then (or bigger and change the injector constant in the prom.)
take care.
take care.
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
