Fuel Pressure Q's
Old Sep 26, 2001 | 04:59 PM
chevyboy07 91's Avatar
Fuel Pressure Q's
whats up guys, I'm trying to get this dang thing ready for the juice but have a couple more questions left.
1. Can I check my FP when the car is running using a handheld FP guage, or do I need a permanent guage of some sort?
2. I have SLP runners and it looks like a royal beeatch to even get to the schrader valve on the fuel rail...what should I do? Any of you guys have that problem?
3. The car has 80,000 original miles and I really don't want to change the pump. What do you think? I'll be hitting it w/ a 150 level.
thanks fellas
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Sep 26, 2001 | 05:51 PM
robert1's Avatar
Did you try unbolting the map sensor? You can check both pressures w/o moving. Connect the gauge, and turn the key ON only. The pressure will jump up to the max(no vacuum). Then, start it, and check the vacuum pressure, and verify max and take the vacuum line off.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
