first time to track!!!!86 TA 1/4 times!!!!
Old Sep 23, 2001 | 12:42 PM
kernel's Avatar
well i didnt do very good. i went with a really bad set of tires and the car is missing pretty bad, and idiling REALLY bad. anyway. my first run was
r/t.. .752
60'.. 2.379
330.. 6.750
1/8.. 10.417
mph.. 65.86
1000.. 13.721
1/4.. 16.575
MPH.. 78.59
THAT WAS LEAVING IT IN OD
i ran 4 more times that day(running a 16.181,16.096,16.051, and my last run....
r/t.. .751
60'.. 2.314
330.. 6.657
1/8.. 10.259
mph.. 68.48
1000.. 13.364
1/4.. 16.015
mph.. 84.45
after the first run i started shifting manually and had a better run each time i raced. i think i could have hit some low 15.9's or some high 15.8's if i would have had some better r/t's and 60' times. i just couldnt get used to the light. and i couldnt find a way to launch the car. i tried mashing it and it spun like crazy, and then i tried to hold the gas and brake and drop it at the line and it still spun. but i had a blast and i am going back real soon. anyway if the car was running good and i had some decent 60' times i think i could have hit some 15.6's. what do u think?
1986 WS6 pontiac trans am
5.0 305 TPI V8, 2.77's,
700R4 tranny w/transgo shift kit.
B&M holeshot 2400 torque converter,
borg warner wires,accel cap and rotr,delco plugs, K&N
KYB shocks,dynomax high flow cat,3"intermediate pipe,40 series flowmaster
w/2 3" tailpipes.
"ponys can run but birds can fly"
www.community.webshots.com/user/kernel20
[This message has been edited by kernel (edited September 23, 2001).]
Old Sep 23, 2001 | 03:24 PM
Jason87GTA's Avatar
Not too bad for 2.77s and bad tires. Here are some things that will help you get a bit quicker.
Install AFPR to bring that FP up.
Check base timing and make sure you're at 10-12 BTDC (assuming you don't have a chip).
If budget allows, get some 3.42 gears to get into the lower 15s.
Jason
Old Sep 24, 2001 | 08:47 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
yea man not bad i hit a 16.09 with 12 dergees of timing retard on a 3.08 open diff rear with bald tires. then fixed timing and hit a 15.1 with a 2.73 rear open diff. so u are on track. mods are below
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
Old Sep 24, 2001 | 09:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I wouldn't say "not bad". Not to disrespect, but my stock '87 LG4 ran 16.0's all day long. That was w/ 2.73 peg leg rear and crappy tires. Just by converting my LG4 to Tuned Port put me in the low 15's
Definatly do all the "free" mods, and get some headers. Other than my TPI retrofit, the headers was the biggest improvement.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 27, 2001 | 10:48 AM
u r sofa king we tah did's Avatar
fun isnt it?
[This message has been edited by u r sofa king we tah did (edited September 27, 2001).]
Old Sep 27, 2001 | 02:28 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Not a good idea to put it through that abuse if it is missing and idleing so badly...
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
