89' IROC Wont Start
Old Sep 27, 2001 | 12:15 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
89' IROC Wont Start
Well if it's not one thing it's another. first the brake problem now this. well anyways i started it yesterday and it did start. it died out on me and didn't want to start again. well i pulled the codes and got a 21 TPS. well i have since replaced it and adjusted it to .54VDC and the damn thing wont start. it cranks and then the engine stops turning over and then it gets going again and backfires through the exhaust. i disconnected the bypass connector, in depairation, and the car sounds like it wants to start but it wont. i'm guessing an ignition problem or computer problem. guys please help me out here before i was kidding about the bonfire thing but now i am more serious than ever. well thanks for your help anyone.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Sep 27, 2001 | 01:07 PM
leirch's Avatar
Are you getting spark? Are you getting fuel?
Old Sep 27, 2001 | 01:53 PM
89FormulaL98's Avatar
most likely a spark or fuel prob.
here are the things that made my car do what you discribe. (it wouldnt start alot)
coil, fuel pump relay, injectors, ignition modual. i hope for your sake its not the injectors.
Old Sep 27, 2001 | 03:03 PM
Drakar's Avatar
Are you getting any new codes???? have you reset your ECM since replacing the TPS????
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 27, 2001 | 03:17 PM
Car: 1988 IROC-Z
well guys thanks for the replies. i have found the problem. on my way to testing the ignition module the problem was the distributor rotor had broken. kinda crazy but i am relieved that it wasn't something big.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
