fixing dented intake runners??
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Hi everyone, well I am in a little delema with my mechanic. He dented my stock runners when changing the EGR valve on my 86 IROC. Well needless to say I want that fixed because my car only has 35,000 and I like to take it to shows without dents that I didnt even cause!! So, is there a way to fix a slightly dented runner?? Car is stock and I want to keep it that way, (For now anyway)... Please help!!! I have even looked around for replacements but I cant buy new ones I guess.
It depends on how large the dent is. A small dent may be straightened by passing a brass ball that is slightly smaller (.005) than the inside of the runner through the runner past the dent. While doing this the dent should be massaged with a body hammer. It will make the dent completely unnoticable with the factory finish. A shiny finish will always show any irregularity in the runner.
John
Heart of Texas Power and Performance
John
Car: '97 Z28
Engine: 5.7
Transmission: M6
I was able to push out a small dent with the rounded "ball" that some screwdrivers have on the end of the handle.(depends on how far into the tube the dent is.) If it still shows a little from the outside, try blending it in by lightly brushing with one of those green scouring pads.
87 Formula 305TPI T5
Cat Back, Underdrive Pulleys, AFPR, Chip, Etc.
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
A guy a while back said he took his runners to a repair shop for brass instruments. I guess they have to use the same kind of equipment to take the dents out of flutes and saxophones and stuff. They can also polish the stuff up pretty well.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
