should i go from tbi to tpi
Old Sep 24, 2001 | 08:12 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
iguy i met the other day offered me everything i need to put tpi on my 92 except for the wiring harness he said if i give him the wiring harness and 300 bucks hell put it on for me should i do it and how much horsepower gain should i see
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Sep 24, 2001 | 10:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My dad converted his stock TBI 305 over to stock TPI, and gained 17 HP and 70 TQ at the rear wheels. Its definitely worth it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 24, 2001 | 10:46 PM
u r sofa king we tah did's Avatar
lets see here:
1, you will get better gas milage.
2, you will have ~20 more horsepower.
3, your torque will shoot through the roof compaired to tbi.
4, throttle response will beat the hell out of tbi any day.
5, your emissions will be cleaner.
6, it looks a hell of alot cooler than tbi
id say go for it. thats a good price
Old Sep 24, 2001 | 11:37 PM
camaro89RS's Avatar
I would go for it. I did this swap this summer and have no regrets. I would change the cam while you are at it, and remember that you need to change the fuel pump too.
Jason
Old Sep 25, 2001 | 07:27 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Yes, then you can begin to live up to your internet name
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Sep 25, 2001 | 10:52 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Kev, didn't your dad also use the stock TBI wiring harness just modified (cut/spliced) to run 4 injectors/driver instead of 1?
Just curious, cuz i hate to see TBIers afraid of the swap cuz of a non-existent wiring issue. Of course you'd still have to repin the harness to run the 730 unless you kludge the TBI computer to run it (which IIRC you tried too, eh?)
I just want to get this straight once and for all. We really do need an FAQ building board again...
Old Sep 25, 2001 | 01:25 PM
Kevin91Z's Avatar
Yes, my dad repinned his stock TBI harness to use the TPI 7730 computer. We tried to get the TBI intake to use the 7730 computer, but was unsuccessful. The TBI is double fire while the TPI is single fire. The car was way lean. It would run if we put 454 injectors in and pumped the fuel pressure way up, but thats not a good option. So we shelved that idea until we have more time to play with it.
Old Sep 27, 2001 | 09:47 PM
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
if i get the tpi its going on my 92 not my 89 which is a bad *** 89 camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Old Sep 28, 2001 | 08:25 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I would do the swap, but I'd give him 200 bucks and then do the swap myself. Also,I am sure that your 89 305 camaro is one of the baddest 89 305 camaros on this board, but do not list the huge white chevy symbol on back as one of your mods. You are getting very close to ***** territory with your large stickers and flamboyant spoiler. Just be careful
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
