Trying to get 383 running with 730 SD setup - need advise.
Old Apr 14, 2008 | 11:39 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
So just trying to get the 383 to idle and run OK. Seem to be fighting a really rich condition, and you have to hold the TB open to get it to idle. Seems to run better if you create a vac. leak by unplugging a hose.
It's a 383 with Dart heads, 234/244 intake/exh duration at 0.050", 730 ECM with fastchip PROM, 30LB injectors, SLP runners, ported upper, 52MM TB, MSD dist, headers. Everything is new, wiring, sensors, etc.
Engine seems really really rich. Had to change the oil due to the gas in it.
Seems like I am missing something simple.
Ideas?
Mark.
PS. Sorry if I forgot any details.
Old Apr 15, 2008 | 12:19 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Trying to get 383 running with 730 SD setup - need advise.
Did you tell Ed Wright what the car was doing and did he burn a chip for your current mods? You need to log some data to see what the car is really telling you, do you have a scanner or laptop/cable?
Old Apr 15, 2008 | 07:12 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
We gave Ed all the details on the motor. So the next steps seem to be a data log. I'll have to dig up my old software and cable and see if I can get it to work again. It's been a while.
Mark.
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
jackhammer
Aug 15, 2015 10:04 PM
sreZ28
Aug 14, 2015 07:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
