Where do these go?(Pics)
Old Apr 19, 2008 | 03:03 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I cant figure out where these electrical connectors go and what they are for. Anybody have any ideas?
http://s214.photobucket.com/albums/c...t=DSC03104.jpg
http://s214.photobucket.com/albums/c...t=DSC03103.jpg
http://s214.photobucket.com/albums/c...t=DSC03102.jpg
Old Apr 19, 2008 | 03:16 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: Where do these go?(Pics)
did you pull your ac or air pump...Ive got the same connector on mine and I think it came off my evaporator or my emisson pump
Old Apr 19, 2008 | 07:44 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yeah I did pull them off but im pretty sure thats not what they are for.
Old Apr 19, 2008 | 11:43 PM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
The first plug is for a sensor that has two vacuum lines running to it and then that plug. It is supposed to be mounted to the intake with the same bolts holding the ignition coil. The other plug looks like the one that hooks up to a temp sensor on the underside of the intake plenum, your gonna have fun trying to hook it up w/o taking off the plenum. Good luck dude.
Old Apr 20, 2008 | 07:50 AM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
Bud is correct on the second one for sure. It goes to the underside of the plenum. I had to fish mine out from the back side of the engine when I changed out intake manidolds.
Old Apr 20, 2008 | 03:38 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I know the second one goes to the IAT sensor under the plenum because it is hooked up there. I need to know where it plugs into on the other end.
Old Apr 21, 2008 | 10:24 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
the other end up the wire from the IAT goes to a wire in the back by the wire wall. it actually might be the third pictures wire see if theyre the same connections. and the first one does go to the egr solenoid thing which should be on a bracket on the passenger side 2 rear intake manifold bolts with the coil on top of it.
Old Apr 22, 2008 | 02:53 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I got them figured out now. Thanks
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
