Recommend a chip for a 350TPI with a T5?
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I recently swapped out my stock 5 liter for a 350 long block (an L05). The has been running ok for the last 4000 miles on the stock EPROM, but I'm having a few little issues here and there. I'd like to swap out the chip before I rip into anything else.
Can someone recommend a good chip (manufacturer, burner, etc) for this set-up? I know little to nothing and my research within these boards thus far hasn't helped a whole-lot (too much info at once?!).
I can't get any cam specs (can you believe GM won't disclose this?! And I can't find it anywhere on the Net), but I'm unsure if this is needed to burn the chip. Here's the info on my setup -
350 TPI (brand new L05 block, originally used in caprices and the older impalas). Stock TPI intake.
All stock electronics from original 305.
T-5 manual tranny.
You guys rock!
M
'89 TA - 5.7 TPI (L05, was originally a 305TPI), T5-WC, 3.08 Posi (Drum)
T-5 manual tranny.
You guys rock!
M
http://www.fastchip.com/ is one source. They will get you in the ball park with your combinaion. I started with their chip and had a local chip guy fine tune it on a dyno for a few more ponies.
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Mike
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I think the cam in the L05 is something like 191/198 and .420 lift or so, but I am in no way sure of this.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
