Anyone using this Cam or have the specs on it?
Old Oct 4, 2001 | 05:24 PM
lexussc94's Avatar
Comp cam #12-417-8 Anyone use this on their tpi setup? I was rec this cam for my 406 superram. Any good, Anyone know the specs? Thanks
Old Oct 5, 2001 | 07:07 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It's a hydraulic roller cam with 218/224 degrees of duration at .050" lift, 270/276 duration at .006" (advertised duration), .495"/.503" lift with 1.5 rockers, and a 112 LSA. Excellent cam for a 350, quite small for a 406, especially with a SuperRam. I'd get at least the 224/230 or even the 230/236 since the extra displacement can stand the increased duration. If you're concerned about the idle quality and/or emissions with one of these cams, you can get it ground with a 114 LSA to smooth things out some. I'm not sure if the cam you were recommended is for earlier engines (retrofit roller lifters necessary) or a direct replacement for a TPI engine, so you'll need to look into that (CompCams has a website with all of the pertinent info).
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 5, 2001 | 10:40 AM
lexussc94's Avatar
Thanks for the info Greg!
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
