Ignition control
Old Oct 4, 2001 | 03:40 PM
tpi4me's Avatar
Ignition control
Can you guys suggest a good ignition system for my setup, (edelbrock performer heads, T.E.S. headers, on an L98? MSD 6AL?
Old Oct 5, 2001 | 07:01 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Distributor, coil, plugs and plug wires should do it. In all seriousness, GM makes a brand new HEI distributor that's a direct replacement for small-cap TPI models (part number 1103952), and it only costs $160 from Dal at VanDevere Olds. Or, you can get an MSD distributor for ~$280. Accel, MSD, and Crane all make replacement coils. They and Taylor also make plug wires, although you'll want a cut-to-fit set. My Taylor 8mm Spiro-Pro wires have held up fine the past 3 years I've had coated headers on my IROC. The MSD box isn't really necessary unless you're running nitrous or a blower, IMO, and is just one more extra part that can fail.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 5, 2001 | 04:22 PM
pontiacpete's Avatar
i run the jacobs pro street ignition with the external ultra coil replacing the coil in cap very happy with the setup
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
